LinkBack (9) Thread Tools Display Modes
Old 04-24-2008, 06:26 AM   #241 (permalink)
06blaksi's Avatar
Originally Posted by tek9j View Post
I think you forgot the part where you had to disconnect the negative battery pole. Also, I installed an AEM CAI and now my check engine light is coming on. I unplugged the battery, check the sensor plug, pushed the wires in, plugged the sensor plug back in till I heard the snap, plugged the battery back in, let it idle and the light stayed off until I got to work then I came back on when I went on my lunch break. The install is exactly how you have it here with hoses, placement and everything. Any ideas what could be causing the check engine light to come on?
Sounds like you have the first run of AEM intakes which were throwing CEL's. Injen has never thrown one. If you have an earlier AEM, i would recommend changing it
06blaksi is offline
Old 04-25-2008, 01:23 AM   #242 (permalink)
tek9j's Avatar
I just bought this AEM intake brand new online. I was gonna go with injen but chose to go with AEM because they were the only one I could find with the two piece setup so I could possibly put the bypass valve in between so it won't suck in water. So is this a known problem with AEM or was it a known problem before? The model I have is the 21-519.
tek9j is offline
Old 04-25-2008, 02:37 AM   #243 (permalink)
I do look like a monkey
Jeremy
It's new for us Honda's because of the MAF setup. But it's the first outcome of the AEM intakes that throw the CEL's. If you're brand new, just go get your code checked... it's free. See what the code actually is. For all we know it can be something else.
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG
mad monkey is offline
Old 04-25-2008, 07:58 PM   #244 (permalink)
tek9j's Avatar
I just got my code checked and the code is "P0172 System Too Rich". I got it turned off too but I know eventually its gonna turn back on. I guess the intake is making the fuel burn rich. I thought the car was already burning the fuel rich cause I see that black residue on my exhaust tip since I got the car after I put a few miles on it. Can I do anything about this code?
tek9j is offline
Old 04-26-2008, 02:24 AM   #245 (permalink)
Jeremy
Well the fuel itself doesn't burn rich. Without technicality, it just burns. It's the amount of fuel determined from the ECU that regulates whether you run lean or rich. And the black "soot" on your exhaust tip is just carbon. It's the residue from the exhaust itself. Every exhaust you see will have a black tip. If it's white, then they're most likely running C16 race gas or any equivelant. Seems like you've got the older version of the intake. Go buy some cams to help compensate you running rich . Other than buying another intake of the revised family, you really have no other choice than to live with the light or hope that it doesn't come on.
Old 04-27-2008, 10:12 AM   #246 (permalink)
tek9j's Avatar
Wow... okay. I guess I'll call AEM and see if I can have it returned so they can send me a good one because when I called the AEM tech he said that the check engine light shouldn't come on. So I'll see. Thanks for the info. As for the cams... I heard that the cams already on the si are the best cams calibrated for that engine. So you could get cams but the ones on the engine are already the best you can get for the k20z3.
tek9j is offline
Old 04-28-2008, 12:40 AM   #247 (permalink)
Jeremy
Wrong... we cams we have are pretty high up in the performance ranking, but are far from the best. A mild upgrade is the 06+ TSX cams which give a little more lift than ours. Then after that you'd move to the aftermarket side. Buddy club, Crower, Skunk2, etc. Unless you own a ferrari, or a 100,000+ car. There are better cams out there for your motor lol.
Old 05-12-2008, 09:53 PM   #248 (permalink)
The C Tripp's Avatar
Chris Tripp
very nice, i have an EX and i had my friend Jose do it for me (he has an Si) but he's a mechanic anyways but whenever i upgrade, i would like to do it myself!
The C Tripp is online now
Old 06-04-2008, 01:00 PM   #249 (permalink)
Zephbane's Avatar
Huge problem.
So I bought an Injen CAI from a member here. She said that the MAS port on the CAI didnt match her FG5 MAS. So I bought it from her, not knowing that the MAS is the same for both cars.
So I disassemble my entire car. Get the CAI routed up. Go to connect the MAS to the CAI...
The CAI has a rectangular mount. The Civic Si hs a round MAS. Very upset right now.
Anyone have any suggestions? I just went to injen's website and looked for a local dealer around 75243 (Dallas, Tx) and it didnt show any.
What are my options...
Zephbane is offline
Old 06-04-2008, 02:13 PM   #250 (permalink)
xrs54's Avatar
this DIY better still be sticked next may when i finally get my Si, mods...!
thank you
xrs54 is offline
Old 06-05-2008, 05:31 AM   #251 (permalink)
Jeremy
Originally Posted by Zephbane View Post
Huge problem.
Some pictures would help alot. I'm not sure what you're talking about with "MAS". If you don't mean MAF then you're gonna have to post pics to get further help.
Old 06-05-2008, 10:55 AM   #252 (permalink)
Zephbane's Avatar
Situation solved. 8thCivic member is going to give me refund, and I had Corsport overnight me a new Injen CAI.
And yes, I meant MAF :)
Zephbane is offline
Old 06-05-2008, 01:13 PM   #253 (permalink)
xrs54's Avatar
^good to hear
xrs54 is offline
Old 06-06-2008, 12:58 AM   #254 (permalink)
Jeremy
Ohhh haha... well good that everything is cool now.
Old 06-06-2008, 01:10 AM   #255 (permalink)
Zephbane's Avatar
Question:
I finished installing the Injen CAI today. And while putting no my bumper, I noticed the drivers side was having a hell of a time getting back together. As if something was obstructing it. And low and behold, the CAI was bumping up against my OEM Fogs.
I haven't done any adjustments yet, but has anyone else had this issue. And if so, how did you solve it? I wasnt able to install my new retro headlights yet, so this weekend/next week when I get the replacement parts I need and I install it, I'm gonna tweak with the CAI..
Any input would be greatly appreciated :)
Zephbane is offline
Old 06-26-2008, 12:57 AM   #256 (permalink)
Matt
Installed mine today along with P2R tbs. I wouldn't say it was too difficult of an install but I had to take frequent breaks due to the fact that it was 110 degrees outside. Arizona sucks! Took it out for a drive afterwards and it felt like I was rubbing up against some hosing when shifting into first. Shouldn't be too difficult to re-arrange things but will have to wait until tomorrow when its light out again. Overall it sounds awesome, especially at , but I could swear I hear the injectors firing more so than before. Could be that i'm just listening more closely than before but anyone else notice this?
Silvr08Si is offline
Old 06-26-2008, 11:08 AM   #257 (permalink)
WHTVTEC's Avatar
Daniel
Thanks for the DIY. I used this to do mine, cleared my side front turn signals at the same time. Bumper off to Bumper on it took me about 4 hours for both things, but it was the first time doing a CAI and used a heat gun on my lights (BTW I recommend the oven trick). I noticed a bigger kick at VTEC but the noise is WAY louder from 3k to 5800 than it was before. I don't even have to hit VTEC and it really growls. Love the sound, gas mileage has gone to crap, but oh well it's worth it. Again thanks for the great DIY helped a lot.
WHTVTEC is offline
Old 06-26-2008, 02:48 PM   #258 (permalink)
Matt
shouldn't it be the other way around...thought you were supposed to see a slight improvement in mpg
hmm..strange
Old 06-27-2008, 02:15 AM   #259 (permalink)
Jeremy
hmm..strange
CAI's have a tendency to rob you of gas mileage since majority of the CAI's made out there make you run on a rich side. They also rob you of your low rpm power so you have a tendency to floor give it a little more gas.
As for your first gear problem, make sure the piping/coupler isn't too close to gear selector on the tranny. Have a friend sit inside the car and go from 1st to 2nd to 3rd. While you watch the gear selector move around. See if it's hitting, if it is, just loosen the couplers and push back on the piping toward the fans. While pushing them toward the fans, tighten everything up. That should solve the problem.
Old 06-27-2008, 03:09 PM   #260 (permalink)
Matt
Thanks, that solved it
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18536-diy-injen-cai-install-si.html
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-26-2008 11:18 PM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 01:38 AM
DIY * Injen CAI install * Si - Page 11 - 8th Generation Honda Civic Forum This thread Refback 01-31-2008 03:02 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum
