Old 07-09-2007, 02:29 PM   #1 (permalink)
8thcivic Sponsor
Sway Bar reinforcement brackets.
Just so I can get an idea of how many to make lets get the list going. Sign the list only if you are seriously interested in getting them.
1-Highrev1
BUY MY CIVIC
Highrev1 is offline
Old 07-09-2007, 03:23 PM   #2 (permalink)
dREsTrUcTiON's Avatar
Andre
Would these brackets be made to address the problem of the rear subframe breaking with an aftermarket swaybar?
dREsTrUcTiON is offline
Old 07-09-2007, 03:37 PM   #3 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
1-Highrev1
1-Highrev1
2-8thgenuser
Next NorCal Meet - North Bay
- 8 t h g e n u s e r -
8thgenuser is offline
Old 07-09-2007, 03:39 PM   #4 (permalink)
truflip's Avatar
1-Highrev1
2-8thgenuser
3-truflip
question, whos makign these? how much and how soon can i get one
truflip is offline
Old 07-09-2007, 03:40 PM   #5 (permalink)
CNUco2007's Avatar
Eric
will they require welding?
CNUco2007 is offline
Old 07-09-2007, 03:47 PM   #6 (permalink)
Webby's Minion
8thgenuser's Avatar
FYI, the brackets are in response to the problem mentioned in this thread:
http://www.8thcivic.com/forums/showthread.php?t=43284
The details of the reinforcement design can be found there as well.
Old 07-09-2007, 04:09 PM   #7 (permalink)
8thcivic Sponsor
Originally Posted by truflip
1-Highrev1
2-8thgenuser
3-truflip
We will make them, ASAP. Price is dependent on how many people we get, and these will be bolt in no need to weld but wouldn't be a bad idea if its easily avaible.
BUY MY CIVIC
Highrev1 is offline
Old 07-09-2007, 04:11 PM   #8 (permalink)
Andre
1-Highrev1
2-8thgenuser
3-truflip
4-dREsTrUcTiON
Old 07-09-2007, 04:44 PM   #9 (permalink)
jeff witt
yes
count me in.when and where can i get one?thanks
jj71 is offline
Old 07-09-2007, 05:43 PM   #10 (permalink)
CNUco2007's Avatar
Eric
1-Highrev1
2-8thgenuser
3-truflip
4-dREsTrUcTiON
5-jj71
6-CNUco2007
Old 07-09-2007, 06:02 PM   #11 (permalink)
Andrei
Someone please compare the oem Si rear lower control arm to the non Si (DX/LX/EX) rear lower control arms. Why does hondanews.com list the Si as having "heavy duty hubs" and "heavy duty control arms" over the non si?
If thats true what makes them heavy duty? Thicker walls, brackets? Made from aluminum?
This is from www.hondanews.com. Link: http://www.hondanews.com/categories/957/releases/2778
"Civic Si Exclusive Suspension Tuning To achieve razor-like performance, the Civic Si has the following exclusive suspension tuning compared to the 2006 Civic Coupe:
Front spring rate increases 17 percent
Rear spring rate increases 14 percent
Track tuned front and rear damper settings
Solid front 28.0 mm stabilizer bar (up from 25.4 mm tubular)
Solid rear 17.0 mm stabilizer bar (up from 11.0 mm)
Heavy duty front wheel hub and bearings
Heavy duty front and rear lower control arms"
Pic of 07 Civic LX rear lower arm:
Pic of 07 civic Si rear lower arm:
-The same? The two knucles you see in the pic the one labeled 4 and 8 belongs to the Si.
-The si lower rear control arm is $157 (each) at: http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
The Civic LX rear lower control arm costs: $147
The idea (of course not cheap) since the bracket broke on the non-Si that your problem would be solved if you got Si lower control arms.
Now someone go and compare the two control arms. Meanwhile I'll see what I can do.
Andrei'sCivic is offline
Old 07-09-2007, 06:27 PM   #12 (permalink)
Cr8tive_leo's Avatar
Adrian
What? I've had no problems, nor do I know of any other 8th gen in my area (or 200km radius) that has had any problems with changing the rear sway bar to either the SI or Progress rear sway bar. Without changing the control arms. (I drive harder now than I did before)
How many instances have there been? what stresses were put on the break point? Were the parts lubricated and installed properly?
Just my $.01
If you're basing the failure of the non si, with the non si control arms, it's not the control arm that failed, it's the metal of where the mechanism was that gave way, a defect of the metal under the stress of the sway bar / control arm.
Cr8tive_leo is offline
Old 07-10-2007, 01:50 AM   #13 (permalink)
mbringle's Avatar
Michael Bringle
Count me in:
1-Highrev1
2-8thgenuser
3-truflip
4-dREsTrUcTiON
5-jj71
6-CNUco2007
7-mbringle
mbringle is offline
Old 07-10-2007, 09:14 PM   #14 (permalink)
HAMBURGER!!!
wannapar3's Avatar
I'm up for it also.
1-Highrev1
2-8thgenuser
3-truflip
4-dREsTrUcTiON
5-jj71
6-CNUco2007
7-mbringle
8-wannapar3
FRIENDS DON'T LET FRIENDS DRIVE JUNK!!
http://www.showmotive.com/
wannapar3 is offline
Old 07-10-2007, 10:38 PM   #15 (permalink)
Yeah, I'm in!
1-Highrev1
2-8thgenuser
3-truflip
4-dREsTrUcTiON
5-jj71
6-CNUco2007
7-mbringle
8-wannapar3
9-rc46er
rc46er is offline
Old 07-11-2007, 02:16 PM   #16 (permalink)
8thcivic Sponsor
I agree its the metal that the endlinks connect to that are causing the issue.
I have made some templates and am finalizing dimensions these should be done by the end of next week.
BUY MY CIVIC
Highrev1 is offline
Old 07-11-2007, 02:20 PM   #17 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
i wouldn't buy it right away, but when I order my rear sway in a few weeks I would deff want a set.
Originally Posted by Gonzo View Post
if I found out I was pregnant at 16 I think I'd be flipping the *#&% out.
jed = hermaphrodite
twistedframe is offline
Old 07-11-2007, 02:25 PM   #18 (permalink)
mbringle's Avatar
Michael Bringle
I getting mine ahead of time so there is no waiting. I just hope this doesn't start the "mods under the bed" cycle I had before *crosses fingers*.
-Mike
07 SSIP
http://www.CygnusX1.net/Civic
mbringle is offline
Old 07-11-2007, 02:33 PM   #19 (permalink)
truflip's Avatar
my RSB arrived today. lol. Im gonna install them and just reinstall them later when the reinforcements are avail
truflip is offline
Old 07-12-2007, 02:22 AM   #20 (permalink)
same for me... after i get the rsb, ill be interested in these.
SpecialisTX is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/47299-sway-bar-reinforcement-brackets.html
Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum This thread Refback 12-18-2007 05:45 AM
