Old 11-05-2007, 07:28 PM   #21 (permalink)
Originally Posted by ct20
So why wouldn't you change the springs if you had to do it all over again?
Was it not worth what you spent to have it only lowered an inch? or do you just not like the way it rides now?
Please share your opinions...
no i mean I would keep the pro kit, they are exactly what I was looking for. Perfect drop and not a harsh ride like other spring companies.
xxbodkinxx is offline   Reply With Quote
Old 11-05-2007, 07:50 PM   #22 (permalink)
Any Ideas how a prokit would look with 18x8.5's???
With 225/40/18 tires??
jblacc is online now   Reply With Quote
Old 11-05-2007, 07:58 PM   #23 (permalink)
about the same as mine. 18x8 8.5 isnt really noticeable like 1/4 inch on the outside depending on offset.
Old 11-05-2007, 08:51 PM   #24 (permalink)
ct20's Avatar
My bad...sorry I misunderstood your post...
Eibach prokit ftw...I will be doing this upgrade hopefully--spring 08...How hard were they to install on a scale of 1 to 10? and yes, I will be using a spring compressor....
ct20 is offline   Reply With Quote
Old 11-05-2007, 10:03 PM   #25 (permalink)
With power tools and a lift I would say a 3. If your on your back it might be a bit tougher.
Old 11-06-2007, 03:00 AM   #26 (permalink)
simons2k's Avatar
Simon
Did you guys install the Eibach springs on the oem struts? I'm curious to see how long your struts would last.
I did the same thing with my S2000 (oem shocks with HR springs). I must have gone over 50k miles before I switched to Tein RA coilovers. I switched because I was ready for coilovers, not because the shocks wore out . I'm hoping I could get the same results with the Si.
simons2k is offline   Reply With Quote
Old 11-06-2007, 03:03 AM   #27 (permalink)
hey you guys i need help please message me back but like my sidemirror is broken and there is no paint damage on the outside its jus the mirror is cracked how do i fix it and i know honda is gonna charge me alot!!! any suggestions please help!!! if my dad finds out im soo screwdd!!!!! (
mervinb is offline   Reply With Quote
Old 11-06-2007, 10:38 AM   #28 (permalink)
Moonkei's Avatar
Aye.
Bot?
Moonkei is offline   Reply With Quote
Old 11-06-2007, 10:44 AM   #29 (permalink)
Rems07si's Avatar
Remy
hey you guys with Eibach Pro-kit how much of a difrece is the ride from stock on a scale from 1-10 and 10 being the most thanks
Rems07si is offline   Reply With Quote
Old 11-06-2007, 12:31 PM   #30 (permalink)
Probably a 2, barely noticed a difference. They are progressive so the harder they are pushed the stiffer they are. Daily driving its almost stock.
Old 11-07-2007, 03:19 PM   #31 (permalink)
So u dont think there would be any fitment/rubbing issues with the 18x8.5's??
Old 11-07-2007, 03:25 PM   #32 (permalink)
Moonkei's Avatar
Aye.
That's what I'm wondering. My new set of wheels is 18x8 and I'm told I'll have rubbing issues if I drop it.
Old 11-07-2007, 03:45 PM   #33 (permalink)
Is this the pro-kit you have, just the springs?
Eibach Pro-Kit Spring Set Front and Rear Fitment
Ride Height: Moderate Lowering
Note: Avg low 1.2"F 1.0"R
Lowering amount may vary with model and equipment.
Orig. Price: $201.00 (kit)
See price in cart
Estimated Availability: Low Stock
Manufacturer Part #: 4031.140
Info from TireRack
And you say that this drop feels the same as stock in terms of ride comfort? I was going to get the HFP, but if the ride comfort is maintained as to almost stock, I may get this becuase it's cheaper and a bit lower!!!
You know my AIM screen name. Let's chat...
llckll is offline   Reply With Quote
Old 11-08-2007, 04:23 PM   #34 (permalink)
who is the cheapest on pro kits?
Ek37 is offline   Reply With Quote
Old 11-08-2007, 04:27 PM   #35 (permalink)
jocasti's Avatar
Got mine from wesellcarparts.com for 200 shipped and yes I type funny you bastard
jocasti is offline   Reply With Quote
Old 01-11-2008, 08:25 PM   #36 (permalink)
tire rack is at 237 with ingalls front camber shipped(-3.3%(7.xx) from fat wallet) .....i guess that is the better way to go really.....
Old 01-11-2008, 11:00 PM   #37 (permalink)
soxfan143's Avatar
I just installed this kit also. I'm also running 18x7.5 and 225/40/18 tires and I have no rubbing. But I would recommend the front camber bolts before you gat the rear camber kit. As long as you have a close to neutral toe in on the rear you will not get any more severe tire wear than stock. And Setting the front camber at around -.8 will make the car handle soooo much better. My car used to understeer BAD in the rain before but now it sticks like glue.
soxfan143 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/63279-eibach-pro-kit.html
Eibach Pro Kit - Page 4 - 8th Generation Honda Civic Forum This thread Refback 12-12-2007 07:03 PM
KAIXEN HID Kit Installation DIY! Excelerate Lighting 13 12-22-2008 10:41 AM
work xd9 18x8.5 w/ work lugs, falkens and eibach prokit $2,130 good deal or not? mocsman Wheel And Tire Upgrades 15 08-03-2007 08:45 PM
What you need to know about HID vs HID kit striker_1818 Lighting, H.I.D.'s, & Neon 54 06-28-2007 08:42 AM
Eibach pro kit pictures pigman Garage 11 05-13-2006 11:54 AM
Search Engine Optimization by vBSEO 3.1.0
