21 - 40 of 227 Posts
FA5SI said:
I reconfirmed with them they said it was 1.5/1.4... hmmm can anybody else clarify this?
The Skunk2 website has actually 2 different sets of numbers... Note the chart below:
However if you select "Buy Now" for the 06+ Civic it states its 2.25/2
I have these springs on a FA5 and I got around a 2" drop... thats not 100% accurate since I didn't measure before and after, so I'm just using a SWAG measurement. However it may be less of a drop on a FG considering the slight weight difference between the two models.
hey i just want my car(07 LX sedan) really low, like slammed low, how much drop do you guys suggest? er are there any springs you guys suggest? i saw a set of neuspeeds there with a 2.0 drop... but im not sure.
oh yah and btw FA5Si; in my search for springs i found 1 so far you forgot.
megan makes a spring kit part number MR-LS-HC06 F/R: 1.5", Springs rate: 250F & 220R
Are these drop rates Before or After the springs have settled? I was talking to a shop about what I wanted to do to my FG1, and I want to avoid (for a while at least) doing a full suspension overhaul. I just want to lower it a bit to get a better stance. He recommended that I could lower about 1.0" without having to really worry about my suspension getting screwed up.
Thanks!
Spring Rate Thread
I have a hard time searching for spring rates of the different coil-overs and springs out there. I've done multiple searches, and have found nothing. Maybe I'm blind? Regardless, nothing popped up and slapped me in the face.
I think it would be to everyone's benefit if we started a thread that had the spring rates of all the coil-overs and springs out on the market. This way, if someone does a search, bam, this is thread is sure to pop up.
Buddy Club N+
F: ???
R: ???
Buddy Club RSD
F: ???
R: ???
Tein Basic
F: 6 kg/mm; 336 lbs/inch
R: 7 kg/mm; 392 lbs/inch
Tein SS
Tein Flex
F: 9 kg/mm; 504 lbs/inch
R: 10 kg/mm; 559 lbs/inch
Progress
F: 4.28 kg/mm; 240 lbs/inch
R: 5.89 kg/mm; 330 lbs/inch
Ksport
F: ???
R: ???
Megan
F: ???
R: ???
etc etc.
What do you guys think?
-Jalal
progress shows the same part number for the si and the non si sedans/coupes...unfortunetly I just found this out the day after I ordered them :p
but here's the spring rate and drop info
Front Rear
1.3” 1.2”
240 lbs. 330 lbs.
Well after doing some searching, I guess it won't be too bad, stock spring rate in front is 200 and rear is 230...so that should work out pretty good for me.
