Q : Fuel Injectors
1 reading
2.1K views 15 replies 11 participants last post by  juicy55908
#1 ·
im plan to upgrade my Fuel Injectors, what size and brand to use?
link please
MOD list:
injen cai
DCRH
Greddy evo2
hondata
hondata img
#7 ·
el_ache_veintidos said:
you won't need injectors, without modifications to them they are good for something near 240 whp, maybe a little less and actually if you put bigger injector right know without any tuning your car will run like crap and you will get the worst mpg ever because the injector pulsation will be to high for those bigger injectors.
ok thanks
#13 · (Edited)
Ummmmmmmmmmmmmmmmmm... You cannot add larger injectors without a way to control them. If you add larger injectors without tuning for them you're going to be extremely rich.
Do you even know what you are talking about? Fuel injectors dont spray the same amount of fuel constantly, though I agree more cc/min than what he needs is unnecessary.
Does anyone know the tech specs on the stock units? I'm not sure what the K20Z3 needs but I would think a swap out to the units in the link below would be a good choice for the OP.
I know the greddy turbo kits uses 370 cc/min so the 310's are probably close to stock if not dead on. Using and injector that has the same cc/min but with a higher pressure is a good thing and would probably create a better fuel atomization.
Saturated Injector SL2-0310
Saturated Injector SL2-0310D (Denso style top)
