Will 15mm bolt-on wheel spacers clear the OEM wheel studs?
1 reading
13K views 16 replies 11 participants last post by  YezzirDoodles
#1 ·
does anyone have any experience running 15mm "bolt-on" wheel spacers? i want to know if the spacer will safely clear the OEM wheel studs and not hit the rim. i've been guaranteed that 25mm will be safe but now I'm wondering if 15mm will fit or not.
this is assuming you DON'T grind down or press out your OEM wheel studs. you run a kics project spacer with pre-pressed studs. and your wheel is not 10x114.3.
comments? ideas? help?
